Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 05-19-2009, 02:34 PM
carhauler carhauler is offline
Rear End Oil Leak.
What's the easiest way to prevent the rear end oil from seeping down the bolt threads?
Carhauler
GTS #40
Old 05-19-2009, 03:07 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Re: Rear End Oil Leak.
I assume you mean the bolts around the perimeter of the center section? If so, check that they're all torqued properly (I had a few loose), then apply a generous amount of black high-temp RTV. That worked for me w/o having to take it all apart.
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 05-19-2009, 03:26 PM
Yes, I am talking about the center section where it bolts to the housing. I'm also going to use a "soft" washer under the nut.
Carhauler
GTS #40
