Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 05-18-2009, 12:38 PM
redcar redcar is offline
Synthetic oil and STP
I usually use STP oil treatment at every oil change, is it ok to mix with Synthetic oil? My 03 Impala has 115K, and my 01 Yukon has 118K. Thanks
Old 05-18-2009, 01:06 PM
maxwedge maxwedge is offline
A990 racer
Re: Synthetic oil and STP
There is no reason to thicken your oil with STP, the point of the synthetic is for better cold start flow, additives are not recommended,.
Old 05-18-2009, 04:00 PM
j cAT j cAT is offline
this STP additive was used widely many years ago ,,,usually on worn engines using alot of oil....it also had the problem of [in cold climates] not fully draining out,,,and causing a lot of debris to stick to the internal engine crankcase...
I would not recomend the use of these additives in these newer vehicles,,,,the engine you have is designed for a thinner oil..
stp would reduce the synthetic oils from doing their job ...which is to reduce wear and friction.....
Old 05-18-2009, 04:40 PM
Thanks Again guys, once again great info!
