Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 05-18-2009, 03:52 AM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
power windows inop
Hi guys
I just took a cream puff 89 Grand Marquis in on trade. The problem is the windows won't work. I replaced all of the clutch bushings that go bad in the motors, and the motors all test good now. The switches all test good as well. I can't find any blown fuses, and swapped all relays I could find. It seems as if I am just not getting any power to the switch. Also the low fuel light is on and the gas gague dosent work. Any ideas guys?
Mike aka JYD
Old 05-18-2009, 07:52 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: power windows inop
Have you checked the relays under the passenger kick panel? The PW relay is there. If you disconnect fuel gauge wire and ground it, it should go to full. If it does, the sending unit is bad. If it does not move, check gauge.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 05-18-2009, 08:14 PM
Passenger side kick panel area. I haven't looked there, thanks. Which wire and where do I disconnect to test test fuel gauge.
Mike aka JYD
Old 05-19-2009, 06:09 AM
way2old's Avatar
TOKEN HILLBILLY
Un plug it at the sending unit. The wire color is yellow with a white tracer. There is also an anti-slosh module in the dash that can cause the gauge to be inoperative. The relay is inside the hole in the A pillar for the windows. There is also a circuit breaker in the system.
Old 05-20-2009, 08:25 AM
Found the green relay behind the passenger side foot kick panel. Found another brown relay buried up under the dash in the center area. Replaced both and still no power those windows. There is nothing in the a pillar of this car. What are the 4 relays under the hood by the washer fluid box for? What is the brown relay located in dash center area for? The green one in the kick panel is the supposed to be for the windows right?
I haven't messed with that fuel tank wire yet. The windows are the priority on this one.
Thanks
Mike aka JYD
Old 05-20-2009, 05:53 PM
way2old's Avatar
TOKEN HILLBILLY
The 4 relays under the hood are for the EEC, Fuel Pump, Horn and A/C. Have you looked in the door boot for a broken wire to the windows? These were bad about breaking wires where the door flexes the wiring. Can't really help with the relay under the dash
Old 05-23-2009, 07:08 PM
There is some goofy old style relay right by the solenoid. It has two heavy yellow wires running to it. It had some red neck wire twist connection. I call those the twist and pray connections, I hate that crap. I soldered the wires back together so that problem is fixed, but still no power to those windows. What is that relay for ? I have a picture in the link below.
http://cmasalvage.com/Hpim5820.jpg
Mike aka JYD
Old 05-28-2009, 02:05 PM
The part number on that relay I talked about in the previous post is. E0VB14A055-AA it says 12 V, 20 A. I can't find any info. on this part number on google. I still don't know what it's for. According to my owners book there is a 20 Amp circuit breaker for the power windows attached to the starter relay. So my next question is where is the starter relay? I am just wondering if this is the part that is causing the problem.
Mike aka JYD
Old 05-28-2009, 04:32 PM
way2old's Avatar
TOKEN HILLBILLY
You can by-pass that for testing. If it works while by-passed, just get a 20 A circuit breaker and install it. That breaker feeds the power window relay. If it is good, check the wiring to the relay from the breaker. Could be a broken wire.
Old 05-28-2009, 07:23 PM
Power window problem solved. The jack ass who owned the car before had the terminal on the negative side of the solenoid. No wonder it wasn't getting any power to the windows. Nothing wrong at all with that circuit breaker. The breaker I showed a picture before is for the power window. I should have seen that problem right away, Duh. Any way thanks for all the help guys.
Mike aka JYD
