Old 05-17-2009, 09:03 PM
jaspermountainman jaspermountainman is offline
93 s-10 won't start intermittently
93 s-10 4.3L TBI, idles rough(loping)when warm and sometimes won't start. It turns over just fine. If I pour a bit of gas into the intake it starts and runs. It always starts cold but is intermittent when warm. I noticed that the injectors aren't firing while trying to start it when it won't start. No adverse performance while driving. When it is idling rough it smooths out if I unplug the idle-air control valve but having this unplugged doesn't change it's ability to start.
Has new plugs, wires, coil (6 months ago). new fuel pump and filters. new idle-air control valve(seems to have helped but this might be a fluke. I haven't been able to check the codes but i'm not getting any error lights on the dash.
Any advice would be greatly appreciated. cheers
Andrew
Old 05-18-2009, 08:41 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 93 s-10 won't start intermittently
When no start check for lose of fuel pressure and spark and injector pulse.
Any check engine lights on or codes set?
MT
Tags
4.3l , s-10 , starting , trouble
