99 Caravan hesitating on freeway
In the past two weeks my Caravan has been having hesitation (ever so slight but it is there), especially on the freeway. it feels like its a problem from the fuel line. It has 117,000 miles. Could it just be the higher ethanol they are putting in the gasoline now, or would there likely be a more serious problem in the fuel line, and how could I tell?
Thanks, cl8
That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved. For with the heart man believeth unto righteousness; and with the mouth confession is made unto salvation. Romans 10:9-10 |
Re: 99 Caravan hesitating on freeway
when did you last have the spark plugs replaced?
Or the fuel filter changed.
if it has not been tuned up yet it is over due. I would start by changing spark plugs, wires, fuel filter, and air filter.
I can't say I remember the last time I had spark plugs or the fuel filter changed, But in march when I had the oil changed I asked my mechanic to inspect my vehicle because I was going on a 300 mile trip, one way, is that something he could have missed?
How often should those be replaced? thanks, cl8
They should be replace at 90K on that model. this will help for sure.
I'm pretty sure I had a 90k tune up but that was quite a while ago.
I just dont want my mechanic to say I need more done than necessary
you might have a bad egr valve also. i just had a 05 doing the same thing and after 8 hours because of no codes were present i figured it out
What I did this year and last year was buy Chevron gas treatment and put that in my tank. It seems to have helped. I figured it might just be the change in the formula for gasoline in the spring thats hard on my engine.
Thanks. |
The air filter had oil on it.
possible fuel pump, common failure..or a engine misfire, a scanner would tell a lot of info
^ I hope not that!
