Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 05-17-2009, 01:36 PM
H23A1Lude H23A1Lude is offline
Send a message via AIM to H23A1Lude Send a message via Yahoo to H23A1Lude
Check Engine Hide-And-Go-Seek
My CEL came on driving home in my OBD1 94 Lude, so I figured okay, I'll get home, shut the car off, hook up the metal to complete the circuit, and count the blinks on my dash (instructions via Chilton's) Well when I connect the wires, I turn the car to the Acc position, and the CEL doesn't come on. So I take off the wires, and try it, and it still doesn't come on. Any ideas?
Internet said use the Blue connector (Looks like this [-|-|-], where each - is a place to put a wire, while Chiltons said use the one next to it with two. Any ideas at all? I'm stuck :[
1994 Honda Prelude Si H23A1
Me: Get new U-Joints, then your Ford won't suck as bad.
Him: Do I need o-rings?
Me: No you idiot.
Him: Sorry, I've never replaced an O-Joint before
Me: FAIL
Old 05-18-2009, 11:58 AM
somick's Avatar
somick somick is offline
Re: Check Engine Hide-And-Go-Seek
Chiltons is not a book to use!!!
The connector is behind your glove box. The one with two wires coming in. It is plugged into a dummy connector. So just pull it out of it and use a paper clip to shorten two contacts.
Your key should be in the ON position, not in ACC.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 05-18-2009, 04:03 PM
Here is what I see. I read a forum saying it's on the drivers side in Preludes. The first picture is behind the glove box, the second is the connector under the driver's side.
Me: No you idiot.
Me: FAIL
Old 05-19-2009, 10:46 AM
somick's Avatar
I missed your car model. Thought that was Accord.
Try to visit other Honda forums, or may be just Google...
Good luck,
Sam
Old 05-19-2009, 03:52 PM
I did that. It seems it only comes on when the engine is at running temp. Coolant Temp Sensor maybe?
Me: No you idiot.
Me: FAIL
Old 05-20-2009, 10:46 AM
somick's Avatar
I would not try to guess, replace parts and hope that you got it. This cost money after all.
I have Haynes manual for 94 Accord. If there is something I can find I will post back.
Sam
Old 05-20-2009, 03:38 PM
That's what I was thinking, and I'm going to college so I can't spend more than I have to. But alright.
Me: No you idiot.
Me: FAIL
