Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 05-16-2009, 10:53 PM
mdhbhouse mdhbhouse is offline
guages come on but engine won't crank
This all started with my horn not working. I checked the fuse etc. but that didn't seem to be the problem and if I removed the horn and connected +- to it it worked.
So rather than messing around with the steering wheel and air-bag etc. I just wanted a working horn so I rigged up a couple of wires to run from under the hood to a switch under the dash that if I press will now sound one of the horns ( I cut it's connector and put one to ground with the other running through my switch to +).
I realize not an elegant solution but I figured I just wanted a working horn.
So now like 8 hours later I have a new problem which is now the van won't start. I turn the key on and the dash lights come on etc. but if I turn the key further to try and start it I get 'nothing'. FUSE?
Update: If I check a little closer today I realize I have no radio either and I think I may have just drained my battery somehow with my 'farmer fix'. So I'm charging my battery and we'll see where that gets me later in the day
MD
Old 05-17-2009, 06:19 PM
Re: guages come on but engine won't crank
Seems like I drained the battery somehow and after charging it for a while it starts again.
I'm going to leave my switch disconnected for now.
Old 05-17-2009, 06:50 PM
CL8 CL8 is offline
Good Luck!
That if thou shalt confess with thy mouth the Lord Jesus,
and shalt believe in thine heart that God hath raised him from the dead,
thou shalt be saved.
For with the heart man believeth unto righteousness;
and with the mouth confession is made unto salvation.
Romans 10:9-10
