Old 05-16-2009, 09:56 PM
jocat54 jocat54 is offline
2004 6.0 misfire
Hi,
I have a 2004 6.0 silverado that sets check engine lite (sometimes misfire#7 and sometimes multiple/cyl misfire-I have a cheap OBD11 scanner). When I clear codes they don't come back except at an idle (not while driving on hwy). Seems to be much worse after driven on hwy, idles pretty well when its cold (open loop) and not to bad even in closed loop if not real hot.Also seems to do pretty well when I put seafoam in the gas.
I have changed spark plugs (wow those iridium plugs are expensive) and plug wires.
Anyone have any ideas where I should start looking?
Thanks,
John
2006 VW Jetta TDI Diesel (Super fuel mileage)
2004 Chevy 2500 6.0 Crew Cab
1993 Chevy K1500 5.7 (love this truck)
Old 05-18-2009, 03:41 PM
j cAT j cAT is offline
Re: 2004 6.0 misfire
Originally Posted by jocat54 View Post
Hi,
Thanks,
John
random misfires are usually a fuel pressure problem..
with a guage measure for around 60 psi at the intake test port...then shut down engine and see if it holds pressure..
this is a common failure , forums are overflowing with this ...a little effort on your part, you should quickly get all that is needed to repair/test for this..
Old 05-18-2009, 06:26 PM
wafrederick wafrederick is offline
Banned
The 6.0s do have problems with intake gaskets and this one thing to check also.They blow out,sucking in air and will cause a miss.Yes,the intake gaskets are made out of plastic.Spray carb cleaner near the intake gasket area and if you hear a change,intake gaskets are bad.Most parts stores stock the intake gaskets since this is a huge problem on the 4.8s,5.3s and 6.0s
Old 05-25-2009, 09:55 PM
okay, I'm feeling pretty dumb here, where is the fuel regulator? Looked on the fuel rails and haven't found it yet.
John
Old 05-26-2009, 09:27 AM
John
the driverside of intake manifold mid point is the regulator...has a vac line going to it...
on passenger side mid point is the fuel pressure test point...
measure fuel pressure and on fuel regulator check that you don't have fuel in the vacuum line...if so replace the regulator..
no vacuum produces maximum pressure....
