Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 05-16-2009, 01:49 PM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
90 olds ciera struggles when warm
3.3 liter engine with 86,000 miles. the other day after driving all day. i parked and shut off. after sitting 10 minutes started and drove 2 miles and then cutout. would restart for just a second or two then die again each time. i then let set for about 10 minutes before trying again. finally would start and stay running will pumping the pedal. smoke would just rollout the tailpipe but made it home like that. the next morning i started it and fired right up with a smooth idle. drove it up and down the road and all was fine. let idle in driveway for awhile and then it started to blow smoke and idle rough and just stay started while pumping the pedal. again would restart and only run a second or two. the following day changed fuel filter but had repeat of the of the last day.
Old 05-17-2009, 09:31 AM
Mrbizness1 Mrbizness1 is offline
Re: 90 olds ciera struggles when warm
What color was the smoke. Black indicates to much fuel, blue is a sign of oil burning. A sticky EGR valve can cause the encine to run rough.
Old 05-17-2009, 10:04 AM
toddman67 toddman67 is offline
Get codes, follow intructions on this web site www.troublecodes.net
Post results
Old 05-17-2009, 10:52 AM
jackass#1's Avatar
black smoke. no codes stored. check engine light does not come on. in fact no lights come on while in operation. im going to check the pressure regulator next. if that is not working that would cause too much fuel right?
Old 05-17-2009, 01:39 PM
Yes check the regulator. check for signs of fuel on the vacuum side. Best to check with a pressure tester. Removing the vacuum from regulator, You should see an increase in pressure.
Old 05-17-2009, 07:51 PM
jackass#1's Avatar
i removed the vacuum line and the car died. tried again and same result. but on a good note i cleaned throttle body, IAC, and the MAF. they were pretty carbed up. ilde is much better but still died a few times after warmed up. but would start back up and continue to idle (best its ever idled). havent test drove but will do tomorrow.
Old 05-17-2009, 08:21 PM
You could try to pinch the line instead of removing it and see what that does. I ended up replacing all the vacuum hoses and even though they looked good they were bad. Made a world of difference, check the EGR valve as well. Clean it up and make sure it's not stuck open.
Old 05-18-2009, 04:23 AM
jackass#1's Avatar
ill do that after work. thanks
Old 05-21-2009, 03:49 PM
jackass#1's Avatar
egr is clean, was alittle dirty nothing bad. drove today with the same end results. but one thing i did different today was after dying for the 8th time i tried to bleed pressure from pressure regulator. so i took off the tester tip part of the regulator(where you would plug in the pressure tester) and fuel bled out. well i put it back on and it started right up and ran fine for about 6 miles(just a mile away from home), so i repeated that and a alot of fuel poured out this time. but it let me make it home . so would this be a faulty regulator? also no codes were found only 12 showed up.
Old 05-21-2009, 04:07 PM
It would be a good idea to check the system with a pressure tester. Even though it seems to point to the regulator, they are quite expensive $90-$100. Did you try and pinch the vacuum line to the regulator and did it change?
Code 12 is default and will always show. Nothing wrong there.
Old 05-21-2009, 04:20 PM
jackass#1's Avatar
didnt have a tester but by sound it didnt change. didnt rev or anything. ill track down a friend with a tester.
Old 05-21-2009, 04:31 PM
Good deal. I would hate to see you spend money without proper testing.
Old 05-25-2009, 06:13 PM
jackass#1's Avatar
finally checked fuel pressure today. 41psi no change after pinching the vacuum line to the regulator
Old 05-25-2009, 06:30 PM
If you have vacuum to the regulator. You should have seen an increase in pressure when removed or pinched off. The readings that you posted here are on the higher side. The regulator usually holds the pressure down around 37 - 38psi. If you see no fluctuation then I would consider the regulator defective.
Old 05-29-2009, 05:23 AM
jackass#1's Avatar
ok put on new regulator and well still having same problems. yesterday after putting new one on and letting idle, i noticed on the gravel was black residue left by my tailpipe. not to mention it was a very rough idle. could there be a bad sensor even if it doent trip the engine light and leave a code? got to get that pressure gauge back over here and check again. im just getting too much fuel.
