Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 05-16-2009, 05:53 AM
smikkers41 smikkers41 is offline
Exclamation Alternator problems
Please help - I have just replaced the alternator on my Jeep Wrangler 1995 2.5 at great cost but the alternator is becoming extremely hot after only a couple of minutes and only showing 9 volts charge. Can anyone help me as to the cause?
Old 05-16-2009, 07:22 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Alternator problems
Hopefully this will help:
1) Have your battery checked (many auto parts stores will test it for free). A bad battery can cause this.
2) Check your positive battery cable. It can have corrosion (inside the insulation) up to several inches away from the battery. This corrosion can reduce or even eliminate the capacity to transmit voltage.
3) If those don't do the trick, you may have a voltage regulator issue
Also, keep your battery clean...if it gets a whitish powdery buildup near one of the terminals, clean this off and wash it with a mixture of baking soda and water, then rinse well. The stuff on your battery is acid, formed while the battery is charging and emitting hydrogen. The baking soda is a base, which neutralizes the acid.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
