Old 05-15-2009, 12:42 PM
Carfreak18's Avatar
Carfreak18 Carfreak18 is offline
Send a message via AIM to Carfreak18
Sony Xplod HU problem
So i hooked up one of my buddies HU's into my 97 cougar and it took forever to get it to power up and finally my buddy noticed oddly enough that the yellow and red wire have to be touching to power, but its a constant power source so when i turn the key on or open the door the HU stays on, so i bough a toggle switch and some copper wire and hooked it up to that, so now i can manually shut it on and off, has anyone ever heard of anything like this before?
Holland Speedway
Lake Erie Speedway
Tioga Speedway (R.I.P)
Wyoming County Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Many more to come....
Old 05-15-2009, 07:47 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Sony Xplod HU problem
yellow is constant power, red is switched power. If you connect the yellow wire to a switch, then every time you turn off the switch you will lose your memory. The better way would be to connect the yellow wire to the power side of the switch (the one where the power wire from the car is connected) and connect the red wire to the other side of the switch.
Old 05-17-2009, 07:22 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
the radio fuse might be blown causing the radio to not come on when the ignition is on. You could always wire the red to a switch power wire like in the ignition
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 05-19-2009, 12:46 PM
Carfreak18's Avatar
Checked the fuses and their fine, i think i'm just gonna leave it alone, its kinda convenient having a toggle switch.
Holland Speedway
Lake Erie Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Old 05-20-2009, 09:15 PM
AWP9521 AWP9521 is offline
I find it hard to believe that the harness kit if wired to the radio properly didn't provide power to the unit when plugged into the factory harness. You did use a harness kit right?
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
Old 05-21-2009, 12:07 AM
Carfreak18's Avatar
Well yes but theirs a catch, i used a sony Xplod harness from a different HU but they're were both newer model Xplods, are they're different wires that come from the harness that goes into the HU?
Holland Speedway
Lake Erie Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Old 05-21-2009, 08:01 PM
Audio Guy
const power = yellow
sw power = red
ground = black
amp remote = blue/wht strip
illumination = orange
Almost ALL headunits have used this standard for like 20 years but it is possible the harness is wired wrong
Old 12-07-2009, 04:09 PM
dlh2nd dlh2nd is offline
mine does the same thing, but only on radio. if a CD is in, it powers off. it did the same thing in another vehicle as well.
Old 12-07-2009, 06:23 PM
Audio Guy
make sure you have the right harness, and it's wired correctly
Old 12-11-2009, 01:39 AM
KansasZj09 KansasZj09 is offline
Its a Sony, personally i have a Sony in one of my Jeeps and its a pos. I hate to be negative. but the volume turns itself up randomly. Ill be driving paying attention to the road and then bam its like im going from easy listening to a rock concert and it pisses me off. Personally, id rid it and get a different brand, get a brand that wont do that. I have a cheap cheap Wal-Mart VR3 that will out do any Sony Xplod crap Sony has. And this is just a temp cd head unit til i get a dvd indash back. Personally man, your probably be going to spend money on a new head unit soon down the road, so id just save time and junk it.
"Troubles will come, they will pass."-Lynyrd Skynyrd
Old 12-11-2009, 01:40 AM
anyone else agree with me?
