Old 05-15-2009, 10:47 AM
iroc343 iroc343 is offline
radiator petcock
I am working on a 1995 s10 blazer. It seems to be leaking coolant from the petcock. Does anyone know if I can get the petcock out to replace the o-ring? I don't want to replace the radiator because I broke the plastic petcock trying to get it out.
Thanks.
Old 05-15-2009, 03:22 PM
djd99's Avatar
djd99 djd99 is offline
Re: radiator petcock
Thanks.
If it's leaking from the petcock the o-ring needs replacing but be careful taking it out, If you think it's going to come out hard u might want to consider taking the radiator out so so can work on the bench and not taking the chance of breaking it. The time and antifreeze is better than buying a new radiator depending on the condition of the radiator.. It can be done in the truck if you get the lower radiator hose out of the way but it wont be easy as there's not much room to work in that area.
2000 S10Blazer LT 4 Door 4x4
Billet Grille insert
Winter 30X9.5QR15 BFG's All-Terrain T/A KO's
Old 05-15-2009, 03:33 PM
Thanks djd99, that's what I was wondering. The radiator is in good shape. It seems to leak after you shut the engine down and it goes through heat soak. I was even thinking of exchanging the 15lb radiator cap with something less, like maybe a 12lb. I don't use this vehicle for towing and I don't need the higher pressure cap to prevent boilover.
