Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 05-15-2009, 12:22 AM
jtp762001 jtp762001 is offline
Question Water leak
OK...First, I am new and pretty inept at repair work, but finances as they are, I figured I would pick all of your brains before taking this anywhere.
I got home tonight, a dry night, with no issues at all. I had been home for about an hour and went to the garage for a smoke and heard dripping from under the 07 Aveo. It seems to be on the passenger side, kind of right below the floorboard, possibly a little more towards the front end. Being discovered at mindight, I don't have the light to really pinpoint exactly where this comes from...I do know it is water, or at least another colorless, odorless liquid. And it is not letting up...a steady drip.
Any ideas/ suggestions? Thanks
Old 05-15-2009, 07:37 AM
mcthumber mcthumber is offline
Re: Water leak
Ok, I'll take the easy one--
Were you running your AC on the way home? That's the only source of clean water drips I would know of.
Old 05-16-2009, 06:42 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Water leak
That's got to be it, unless the cooling system is for some reason filled with water instead of coolant. We usually get 20-30 of these leaks in the shop over the summer
There's a good chance the evaporator drain is partially plugged and water is pooling up inside. An hour seems like a long time for there to still be a drip. You should find and correct the blockage, if you get too much water in there it will start leaking onto the carpet and cause mold/mildew problems. Mold/mildew in the HVAC box is also a possibility if not corrected, but it doesn't grow on plastic nearly as easily as carpet.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 05-19-2009, 10:19 AM
Re: Water leak
Thanks...I wasn't running the AC, it is still not quite time for that in Chicagoland, especially at night, but I will keep an eye on this. No repeats of the drip yet and no real adverse effects seem evident. I appreciate the feedback.
Old 05-19-2009, 10:48 AM
Re: Water leak
Were you running the defroster? On my '06, the AC compressor runs whenever the defrost or def/floor settings are used (takes condensation off the windshield). Probably the same on an '07.
--Mike
Old 05-19-2009, 10:59 AM
Re: Water leak
Now that you mention that, I was. Thanks for the info.
