Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 05-13-2009, 07:05 PM
drkvamp drkvamp is offline
Question Flasher Install and speakers
I have a 1999 CVPI.. I am wanting to reinstall, headlight and tailight flashers.. I'm under the impression, and maybe someone can verify this for me, that the highbeam headlight wire on both sides is lightgreen w/ black stripe?
I do believe the reverse light power wire is black and pink, correct? What color(s) is the brake light wiring to hook the flasher up to have it alternate between brake and reverse lights?
Lastly... The rear speakers have been removed, presumably by the MN State patrol... What size goes in those, and it looks like I've gotta take the rear seat out to replace them, correct?
All help, greatly appreciated!!
Old 06-26-2009, 06:39 PM
Moose666 Moose666 is offline
Re: Flasher Install and speakers
About your rear speakers...
I have a '98 P71 that saw service with a small town police department. The rear speakers don't work even after I swapped the radio from a crusier that had working rear speakers. Now no longer sure that there even were any rear speakers I pulled up the rear deck to be sure. The speakers are there, the wires are connected and the 'quick-disconnect' at the radio isn't damaged but the rear speakers do not function. I've posted a new thread hoping someone else has dealt with this issue before and can tell me where the speakers have been disconnected so I can fix the problem. Are you sure your speakers have been removed? I couldn't tell until I pulled up the rear deck - I couldn't tell from the trunk side because of the foam housings.
Best of luck to you!
Moose666
