Old 05-13-2009, 01:11 PM
rubberman rubberman is offline
Errattic idle
I am getting fluctuating idle either in park or in Drive(stopped). RPMs jump up and down from 500-900 for about 5 secs then idles fine for a few then jumps up and down again. I get no CEL or codes. I did clean the throttle body out (battery disconnected) and ran fine after that. All intake hoses/lines are reconnected and the 2 wire connectors are attached. any ideas?
2000 Grand Prix GT w/ gold package.
K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe
2004 Chevy Trailblazer EXT
Keep on Keeping on...
Old 05-13-2009, 01:23 PM
bmoody1981's Avatar
bmoody1981 bmoody1981 is offline
Re: Errattic idle
It does sounds like a vacum leak somewhere on the engine. The easyest way to find out is to start the trailblazer and let it idle. Take a can of carb. cleaner and spray it around vacum hoses and the where the gaskets are on the throttle body and intake to see if there are any leaks.
If there is a leak the carb. cleaner will instantly make the idle of the engine jump up due to more gas being placed into the system. I have found that this is the fastest and easyest way to find vacum leaks.
In the end there can be only one.........Chevrolet
Brad
Old 05-13-2009, 02:50 PM
Re: Errattic idle
i did clean the throttle body so maybe somehow a line came loose that i didnt catch. i will thy that, thanks for the tip.
Old 05-13-2009, 09:01 PM
Re: Errattic idle
Well i basically removed everything as i would be doing a throttlebody cleaning. disconnected the battery, removed the intake resonator and TB. all vac lines/hoses were intact. reinstalled everything and started her up and no bad idle. We'll see what happens when the wife drives it to work.
Old 05-14-2009, 08:33 AM
bmoody1981's Avatar
Re: Errattic idle
Ok well keep us posted like to know that we done somthing right.
Brad
Old 05-14-2009, 03:22 PM
maxwedge maxwedge is offline
A990 racer
Re: Errattic idle
When disconnectiung the battery the pcm has to go thru a idle relearn, disconnecting the battery is not required to clean the tb.
Old 05-15-2009, 08:09 AM
Re: Errattic idle
but you want to disconnect the battery so the pcm has to relearn the idle since the TB is now clean.
Old 05-15-2009, 12:58 PM
A990 racer
Re: Errattic idle
Still unecessary, this will happen without the battery disconnect.
Old 05-15-2009, 01:23 PM
Re: Errattic idle
ok well i thought that was norm. learned something today.
Old 05-15-2009, 08:57 PM
Re: Errattic idle
well its doing it again but not as bad. going between 500-900 rpms and you can tell its affecting the headlights.
Old 05-16-2009, 12:53 PM
A990 racer
Re: Errattic idle
At this point if no obvious vacuum leaks, a full scan is in order.
Old 05-16-2009, 05:09 PM
Re: Errattic idle
from a TechII? or would those SnapOn tools work also?
Old 05-19-2009, 08:52 PM
Re: Errattic idle
whats the function or what function is provided by the 2wire connector that attaches to the alt?
Old 05-20-2009, 08:13 AM
A990 racer
Re: Errattic idle
Snap on scanner is ok.
Old 05-22-2009, 11:46 AM
Re: Errattic idle
well since i resoldered that red wire it hasnt done it. its been 3-4 days now.
