Old 05-13-2009, 09:14 AM
expjoe expjoe is offline
Cool P0440
As you know I recently changed out my fuel pump 2 days ago and now my SES light is on, I had the code read and it is P0440. What is my first move here guys??
Old 05-13-2009, 10:41 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: P0440
first move, make sure your gas cap is good, then make sure its on tight
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 05-13-2009, 11:37 AM
Re: P0440
How do I know it is good? Should I clear the code?
Old 05-13-2009, 12:30 PM
Re: P0440
just look at it. if you think something doesnt look right on it, then get a new one.
if i were you, i would just make sure its tight, clear the code, and wait and see if it comes back
Old 05-13-2009, 01:56 PM
doctorhrdware doctorhrdware is offline
Re: P0440
It also could be a problem with the fuel pump assemble o-ring. Since he has replace the fuel pump it is possible that the o-ring did not seal properly.
Old 05-13-2009, 02:05 PM
Re: P0440
How would I know if the o-ring didn't seal properly??Would I have to pull the pump again?? The car runs fine and does nothesitate at all, maybe I will just replace the cap at this point!?!
Old 05-13-2009, 02:18 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: P0440
The fuel tank vent valve is located right next to the fuel pump module. I would take the access cover back off and make sure you didn't accidentally disconnect the wiring harness or the purge hose from the vent valve while changing out the pump.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-13-2009, 02:23 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: P0440
If the O-ring does not seal, you will get a P0440 DTC. Check the simple things first, but anytime the pump is replaced, a new O-ring should be installed. Very common mistake that will come back to haunt you!
Old 05-13-2009, 02:38 PM
Re: P0440
I just double checked the wire harness, everything looks fine, I also looked for the purge hose ; I am not sure which one that is?? Could you give me some direction?BTW the pump assembly came with a new o-ring and it was used(and greased); the pump went in good and tight.
Old 05-19-2009, 10:53 PM
Firstymer Firstymer is offline
Exclamation Re: P0440
My 00' GP SE with 125,000+km 3.1L V6 had pull up that exact same code P0440. Where is the air solenoid? Any pic or diagram to fix the problem?
Old 05-19-2009, 11:01 PM
Re: P0440
Where exactly is the fuel tank vent valve? Any pics or diagram to check for replacement?
Old 05-24-2009, 09:14 PM
Re: P0440
i just filled up and left a good amount of fuel on the ground ..... this would tell me the o-ring did not seal properly. I will be removing and replacing the o-ring and snap ring, maybe it got twisted when i installed it??. thanks for all the help!
