Old 05-13-2009, 07:32 AM
goadster4 goadster4 is offline
Wheel bearings
Can anyone tell me what the warning signs are of a wheel bearing going bad. My traction light comes on in when I turn slow to the left, but don't know if this has anything to do with it.
Old 05-13-2009, 07:45 AM
ricebike ricebike is offline
Re: Wheel bearings
check for codes... maybe its the abs sensor wire that's being stretched out or something when you turned that direction
Old 05-13-2009, 11:35 AM
evo-00 evo-00 is offline
Re: Wheel bearings
Bad bearings will make ABS and Trac lights come on (I guess it would actually be the sensor but bearing and sensor are 1 unit). Make sure your front tires match in diameter.
Rich Good
Old 05-13-2009, 01:39 PM
doctorhrdware doctorhrdware is offline
Re: Wheel bearings
It could be a wiring problem. I would check the speed sensor wiring on the left speed sensor. It is possible that might be a problem with the wiring.
Old 05-13-2009, 02:32 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Wheel bearings
Could be many things making just the trac light flash or come on. If the wires are good, then Id get it scanned with an ABS capable scan tool.
1999 Grand Am SS 3.4 OHV
Old 05-16-2009, 11:43 PM
stoynuts stoynuts is offline
Re: Wheel bearings
I've changed both my hubs around 80k, you'll start hearing a grinding noise, sound like your brakes, except that It will get louder in the corners, If you are hearing a noise, and it gets louder in a left turn and goes away in a right turn then your right hub bearings are bad, and vise-verse.
Old 05-17-2009, 09:52 AM
Re: Wheel bearings
Welcome to AF stoynuts!
A bad bearing WONT make your ICP lights come on or throw any DTC's, unless both the speed sensor and bearing is bad. It'll just make a lot of grinding noise when the car's moving.
