Old 05-12-2009, 09:53 PM
droyalone droyalone is offline
Fog Light Assembly
Does anyone know where I can find the housing for 98 Olds. Intrigue fog ligiht? I can't find one at the pull-a-part nor online. Any suggestions would be welcomed.
Thanks!
Old 05-13-2009, 10:17 AM
dtownfb dtownfb is offline
Re: Fog Light Assembly
Here's the best I can find on the fog lamps:
http://www.gmpartsdirect.com/catalog/frameset.cfm
Also check Rockauto.com
Old 05-13-2009, 09:33 PM
Hey thanks for the gm website. The first time I have ever found the entire assembly. A bit pricey, but for the first time finding one, it's a start.
Does anyone out there have one from the salvage yard willing to get rid of?
Old 05-14-2009, 01:17 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
http://www.car-part.com
They have a network of used parts dealers that you can rummage through.
You might be able to find one close to you, or if nothing else get a contact to call and get a shipping quote on.
You might also check Ebay, theres not too much you cant find on there.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 05-14-2009, 03:10 AM
harmankardon35 harmankardon35 is offline
i was contemplating replacing mine, bit then i realized a $40 set of auto-parts store fog light looked just as good, if not better. I just used a pre existing bolt and mounted them up, connected the wires and i'm glad i did. The factory fog lights kind of suck, not bright and often dirty/hazy.
Old 05-14-2009, 05:57 PM
Thanks for the tips! I am excited to find so much information to restore my Intrigue.
Old 06-09-2009, 10:16 PM
Oldsconnection.com Oldsconnection.com is offline
Buick Regal fog lights will work. Everything is the same except the brackets need to be tapped and use short bolts...1/4" I think is what I used. The intrigue brackets have studs, where the regal brackets just have holes there.
TYC foglights for buick regal readily available on eBay. Work great.
Old 06-10-2009, 12:28 AM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Definitely keep this in mind. The studs that hold the fog light assembly on are very brittle and snap quite easily if you try to remove the retaining nuts. Try soaking them with a good penetrating lube like PB Blaster if at all possible before trying to remove the nuts.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
