Old 05-12-2009, 08:04 PM
HighMileage230000 HighMileage230000 is offline
breather tube missing
97 Windstar 3.8L
I bought the vehicle and there was no breather tube connected to the front valve cover. It did have a fram breather element (obviously NOT what is supposed to be there) and I am trying to figure out where this line is supposed to connect.
Is it possible that it is affecting driveability/mileage by not having this breather tube connected there? I can't seem to find anything about this problem anywhere online and I don't have access to another Windstar to trace the line.
Old 05-13-2009, 08:22 PM
wiswind wiswind is offline
Re: breather tube missing
1997, YES there should be a breather tube to the front valve cover....that goes to a hole in the back side of the big flex hose that goes from the Air filter/MAF bullet to the throttle body.
The PCV line is in the rear valve cover....driver's side......with a line that connects it to the top of the upper inake manifold.....next to the throttle body.
I don't see a listing for the breather that fits into the valve cover.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 05-17-2009, 08:21 AM
The breather that was in there looked like something you would find on a early 1980's Bronco or something, I couldn't find it either (I guess thats why)
Thank you for that information. Yesterday I went out and found the spot where the tube used to connect to. The previous owner obviously broke the tube and then plugged the spot on the air cleaner/flex hose because it was plugged with a 5/8 bolt that looked like it was supposed to be there.
With the help of some vacuum hose and my old PCV plastic breather tubes, I have something that resembles the original.
