Stereo removal
Hi all,
I have a friend with a 69 Chevelle. The stock radio is not working. My first question is how does the stock stereo come out to check the wiring? My second questions is can anyone recommend a location for placement of an aftermarket stereo while leaving the factory stereo in the dash? Thanks Andy
1998 silver gtp, GM performance Handling kit ,cold air intake, KYB struts ,HD supercharger coupler ,Gatorback belts ,U bend delete ,NGK TR6 plugs ,DHP PCM, Electric exhaust cutout - SOLD 98 White GTP, N* TB, 3.0 MPS pulley, SLP headers, 1.9 Rockers, 105# springs, ZZP PCM, Flowmasters, GM performance Handling kit, FWI, GMPP springs, U bend delete, SSIC, Ported LIM, Autolite plugs, ported SC, 12" brake upgrade with slotted cross-drilled rotors, |
Re: Stereo removal
Hi there, I had a '68 and it is quite similar to the '69.
The radios are easy but you have to wedge under the dash as much as possible. You'll need a flashlight or droplight. Pull the front knobs off, and there is a bezel nut on each knob post. Remove the bezel nut. Under the dash there is a bracket arm going from the radio to the dash panel. Maybe two, can't remember. Should be held on by 3/8" or 7/16" fasteners. Disconnect the wiring harness connector and then pull out the antenna male connector and the radio should be loose in your hands for removal. I have seen where folks leave the stock radio in place for appearance, disconnect the wiring and run a modern radio or i-Pod inside the glovebox. Open the door - there it is. Close the door and listen to tunes while still having a fully stock look to the dash. Tom
'65 Chevy Malibu SS '06 Pontiac Vibe (a dead deer fits nicely in the back) '04 Ford Escape GMC S-15 4WD '57 Chevy 210 post sedan '51 Ford F2 pickup Recently gone but not forgotten - 68 Chevelle, '97 Rodeo V6 4WD. |
Re: Stereo removal
Thanks Tom, I will get a look at it.
Andy
