Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 05-11-2009, 08:25 PM
Gulfstream1 Gulfstream1 is offline
`01 SL A/C problem
I think I already know the answer to this question, but wanted to bounce it off people who know more than me. The air stopped working today. I noticed that the clutch doesn't seem to be working (disc on compressor pulley not spinning when a/c is on). I checked the low side pressure, it was at about 100 psi and about 84 degees outside air temp. I have good voltage at the compressor. I assume the clutch is bad. Does this sound right? Thanks for any advice.
Old 05-13-2009, 10:45 PM
RC1488 RC1488 is offline
Re: `01 SL A/C problem
More than likely. The other thing to check is the switch by the fuse box. I can post a video if needed.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 05-14-2009, 05:58 AM
That video would be great. I took that switch off and cleaned it, but wasn't sure how to check it. Is that the pressure limit switch? The wire colors didn't match my haynes manual.
Old 05-14-2009, 08:38 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Do you have power/ground to the clutch? If you do then its bad if you don't than keep looking.
Old 05-14-2009, 08:51 AM
I have power at the connector going to the compresser. I don't think I can check the grounds as they are internal to the compressor. Is it possible to change the clutch itself? Or would it be better to just change the compressor? Thanks.
Old 05-15-2009, 10:28 AM
http://www.youtube.com/watch?v=PMM80...eature=related
http://www.youtube.com/watch?v=T3o1l...eature=related
