Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 05-11-2009, 04:12 PM
Steve'o Steve'o is offline
2001 Yukon XL..power steering issues
On my 2001 XL, the power steering seems to be going out but ONLY on right hand turns....left turns are fine. It is intermitent and very hard to steer even on the freeway at 75MPH ......dangerous also. There is also a 'hissing' noise coming from the firewall when it does become hard to steer. Couls it be ther gear box, PS pump or other. I'm lost on this one.
Old 05-11-2009, 05:57 PM
2000CAYukon 2000CAYukon is offline
Re: 2001 Yukon XL..power steering issues
P/S pump has no idea if you are turning right or left. The gear box is the most likely culprit.
//2000CAYukon
Old 09-15-2010, 09:57 PM
markdpro markdpro is offline
There is a steering sensor at the bottom of the steering wheel shaft, inside the truck, A small disk that turns in a gray housing. GM calls it the steering position sensor. I replaced mine because the steering went suddenly light in smooth left turns. The sensor controls the power steering rate through an electronic orifice in the power steering. Could Be.
Old 09-15-2010, 10:28 PM
There is a steering position module that can cause wierd stuff. It causes the power steering to change its rate of boost.
This module, I bought mine from HELP part #31025
About an hour to replace.
Slide seat fully back
Disconnect neg ground for at least half an hour to Disable air bags.
Remove 15mm nut to separate steering shaft just before it goes through firewall under the dash.
Push shaft off towards, (through the) fire wall.
The device is in a grey housing concentric to the shaft,
Carefully work back the three plastic clips and the disk will come free
Carefully remove locker (a plastic insert) and unclip junction to device lead.
Slide off disk
The plug will slide out if you tease it through carefully.
Clean shaft with electronic cleaner
Install new sensor the brass goes towards the steering wheel.
There is a slot in the top of the gray housing to locate the wires
Tease the coupling back into position reattach and insert lock
Click the sensor in place
Reinstall shaft and bolt.
