Old 05-11-2009, 02:09 PM
jeffwnpa jeffwnpa is offline
Unhappy 97 bravada with codes
my bravada is coding since i changed fuel lines and filter,also broke vent connection on fuel pump, but plugged line ,it had vacuum.anyway it is code p175,p1133,p1153,p172,in that order,and it idles funky now like a misses, when i let up on throttle it takes a few seconds to slow down rpm.cleaned egr valve checked for vacuum leaks has new plugs,wires cap,and button.ran great before fuel line troubles.any suggestion out there.
Old 05-11-2009, 04:02 PM
old_master's Avatar
Advisor/Moderator
Re: 97 bravada with codes
Fix the vent line and attach it properly, clear DTC's, perform a drive cycle and restest.
