Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-10-2009, 08:35 PM
kshook.2's Avatar
kshook.2 kshook.2 is offline
95 lt1caprice
is it possible to switch a 96 back to a 95 because 96 lt1 has the crank shaft positon sensor plus a circle plate with for teeth on it on the crank in front of timing chain on lower sproket what would you have to do to make it stock 95 agian i had put a 96 block and heads in it and yoused every thing from old motor the car runs good and every thing i just would ratheir have it look like stock 95 thanks
Old 05-11-2009, 04:33 PM
96capricemgr 96capricemgr is offline
Re: 95 lt1caprice
Use the 95 damper hub and timing cover and remove the reluctor wheel.
96 Caprice Medium Garnet Red
11.56 at 115.9mph naturally aspirated
94 Caprice wagon, rotted out POS
