Old 05-10-2009, 08:18 PM
Gregmr Gregmr is offline
wheel bearing?
I have A 99 Blazer. When I going down the road I get a humming sound and the steering will shake alittle. When I turn the wheel to the right the noise is not as loud. So I replaced the left side wheel bearing. I still have the noise. Can it be the right side bearing. Can't feel no play on right side wheel.
Old 05-10-2009, 09:05 PM
rhandwor rhandwor is offline
Re: wheel bearing?
Is this a two or 4wd also give year.
Old 05-10-2009, 09:25 PM
old_master's Avatar
Advisor/Moderator
Re: wheel bearing?
2WD and 4WD both have two sets of bearings on each side. Making a right turn unloads the left inner and right outer bearings. If the noise stops when you turn, it could be either one, have to check them with a stethoscope to be sure.
Old 05-14-2009, 08:36 PM
Re: wheel bearing?
It was the right bearing. Thanks
