Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 05-10-2009, 11:20 AM
Don Leja Don Leja is offline
97 Cutlass VATS problem
I would like to make a bypass for the VATS sys. on my car but my keys do not have a chip in them. I gather that there was a type with the resistor on the ignition switch. How would I go about measuring the resistance without removing the switch? I am getting tired of waiting for the light to stop flashing before I can use the car.
Old 05-11-2009, 07:34 PM
maxwedge maxwedge is offline
A990 racer
Re: 97 Cutlass VATS problem
How is the car starting, it must be already bypassed, no? You cannot figure the resistance the module is programmed to see without a Tech 2 scanner, or the key.
Old 05-12-2009, 08:09 AM
I bought the car cheap 2 years ago with the crank case filled with anti freeze but only 50,000 miles on it. It was to hard to do a compression test on the rear cylinders so I just took it apart and replaced the head and intake gaskets. The car starts and runs fine 99% of the time and I have since put 30,000 more miles on it. It is a good looking car and I like it. The problem has never happend to me but when my wife drives it she gets the anti theft light maby once a week and she drives me crazier than the car. I dont know if it has already been bypassed but I know the old guy I bought it from couldnt have done it and he has since died. The dealer would have had no reason to. The keys I have for it are not the original and I dont know why that is. But they are the same style as my 95 pontiac and dont look anything like the VATS keys with the resistor built in.
Old 05-12-2009, 08:23 AM
brcidd's Avatar
brcidd brcidd is offline
That IS NOT a VATS (resistor in key) system, it is a PASSLOCK II system- (resistors in ignition switch) - bypassing Passlock II is a little different- I use a GMATII module ($7 of Ebay) when I do remote starters- but in your case, I would just wire it in permanently so that the BCM always get the proper resistances- have done this a few times on C/K trucks with Passlock II- works great- instructions are in the kit-- if it is still available- other wise just google search for Passlock II bypass. - or search this forum too. Or you can build your own with two relays and a potentiometer- or use fixed resistors- it's all in how you want to do it, and how handy you are with soldering etc...
Disclaimer- Bypassing a GM theft deterrent system will no longer provide vehicle theft deterrent-- but it will start evertime!!!
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-12-2009, 10:49 AM
I'll check that out Thanks for the info.
Old 05-12-2009, 03:04 PM
A990 racer
Question Re: 97 Cutlass VATS problem
As we speak my 97 Cutlass sitting in the DWy has the oe Vats system, chip in key, how come?
Old 05-12-2009, 04:09 PM
brcidd's Avatar
My remote starter info shows 97-99 as Passlock II..
'99 GMC Yukon
Old 05-12-2009, 06:46 PM
A990 racer
I have a 98 W body Lumina next door to me and it has Vats system also. I found a site listing 94-99 as W body Vats years, then PK1. http://mysite.verizon.net/vze7erz1/id14.html
Old 05-12-2009, 08:47 PM
brcidd's Avatar
Great- if there is a chip in the key- then cut the orange sheath and put a resistor across the two white wires that is equivalent to the chip resistance- there are only 14 resistances in GMs line-up for VATS. I thought the OP said he had no chip in his key....
'99 GMC Yukon
