Go Back   Automotive Forums Car Chat > Toyota > General Discussion
Old 05-08-2009, 02:53 PM
uunter uunter is offline
Any advice on o2 sensor brands?
I'm replacing the bank 1, sensor 1 oxygen sensor on my '98 Camry v6. I've seen a wide range of prices on different brands and varieties, and I'm hoping someone with experience can shed a little light on the differences.
I know Denso is the original, and I've found them as cheaply as anything else, so that's what I'm probably going with. But I've seen some talk on the forums about Bosch and Walker, too. Is there a big difference? Also, there are OE fit sensors and universal sensors--the latter are a lot cheaper. Is that because they wear out sooner, or because they'll require jury-rigging to install, or something else?
Thanks in advance.
P.S. oxygensensorsforless seems to have the best prices by far. I'm not affiliated with them; this is not an ad. Just an observation that could be useful.
Old 05-08-2009, 06:13 PM
somick's Avatar
somick somick is offline
Re: Any advice on o2 sensor brands?
I have not replaced O2 sensors on Toyota.
Denso works fine on my Honda. Bosh does not give any problems on my Subaru.
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 08-12-2009, 12:43 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
I'm glad I saw this thread, I just got a O2 sensor CEL code on my Isuzu Trooper.
I checked that site, and I'm going to get the Denso or NGK, I've seen to many negative comments about Bosch O2 sensors in Japanesse vehicles. And the OE type is always a better fit than the universals.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 09-26-2009, 08:10 PM
Itcautomotive Itcautomotive is offline
Denso -Genuine Toyota for sure. They are a bit more expensive than others, but it's what the vehicle came with and should last the longest.
Old 11-25-2009, 01:42 AM
Torch Torch is offline
Buy whatever you can afford but make sure that it has the same factory connector that yours does, the universals sometimes do not have connectors.
Old 12-17-2009, 09:16 AM
NotoriousPhil's Avatar
NotoriousPhil NotoriousPhil is offline
Send a message via MSN to NotoriousPhil
I'd go with NGK they have a new line of O2 sensors and for some reason NGK and Japanese cars allways go well together.
Remember K.I.S.S ( keep it simple stupid )
Old 01-01-2010, 11:56 PM
fourwd1's Avatar
AF -Advisor
Denso would be 1st choice
NGK 2nd.
89 4Runner - stock
