Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 05-07-2009, 11:33 AM
mary68 mary68 is offline
2002 Mazda Protege 2.0
hi, i have a car that suddenly the engine light came on....code is p0171 (system too lean (bank 1) what does this mean.... and what do i have to do to get it fixed..?????
Old 05-12-2009, 04:38 AM
Flash75 Flash75 is offline
AF - Advisor
Re: 2002 Mazda Protege 2.0
It's difficult to say exactly how to solve the problem. Some diagnostic work is required to find the specific item needing service or repair.
Here are some links that may help.
http://repairpal.com/OBD-Code-P0171-and-P0174
http://www.aa1car.com/trouble-codes/page3.htm
http://www.obd-codes.com/p0171
Clifton
Old 06-17-2009, 01:29 PM
Doug Tatham Doug Tatham is offline
Almost every time I've run across a P0171 error it's been because of a vacuum leak. A typical cause is a dry rotted hose. One time I had the error because of the connector between the hose to the pcv valve and the intake boot. Another time was because of the intake boot (tube, whatever). I fixed a friends truck and it was caused by a vacuum hose that went from one valve cover to the pcv valve. Other possibilities usually give additional error codes.
Old 06-17-2009, 02:30 PM
akboss akboss is offline
Just had mine come on after I changed my gas cap to an aftermarket, didn't seal tight and had check engine show up...not sure what the code was but just throwing it out there.
