Old 05-07-2009, 11:13 AM
fy171 fy171 is offline
spark plugs
2002 windstar changing spark plugs i known sopse to use APP 105 autolite,can i use motorcraft SP-486 its finewire platinum plug ,dont kow if its better then double platinum,cant find the app106, SP-486 im told is better,
thanks frank
Old 05-07-2009, 08:26 PM
wiswind wiswind is offline
Re: spark plugs
RockAuto lists the Motorcraft SP-486 for the 2002 windstar, although they list a lot of other plugs that I would not use.
The Windstar calls for double platinumn plugs.....meaning that there is platinumn enhancement on BOTH the center electrode and the ground tab.
The reason for this is that they use a positive spark on one side of the motor and a negative spark on the other.
This causes the center electrode to wear faster on one side of the motor and the ground tab to wear faster on the other side of the motor.
I have used both AutoLite and Motorcraft brands of the double platinumn plugs with success.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 05-08-2009, 09:04 PM
Re: spark plugs
thanks wiswind i finely found the app105 plugs
Old 05-09-2009, 10:46 AM
Re: spark plugs
Great!
They will wear more evenly and last a long time.
You should not need to worry about spark plugs for well over 50K miles.
The correct spark plugs are rated for 100K miles....
1996 3.8L Windstar
Old 05-13-2009, 08:33 AM
Re: spark plugs
replace the plugs and wires and the p171,174 code repair ,now runs much better more power and smoother engine,next change tran fluid and brakes,anybody use R1 Concepts' Eline Performance Brake ,or just go with stock rotor
thanks frank ,great site
Old 05-13-2009, 08:41 PM
Re: spark plugs
I have, pictures in the link that my signature takes you to, of the front disk and rear drum brake jobs on my '96 posted...
I just yesterday ordered Raybestos "Advanced Technology" rotors and Akebono pads through Rockauto.
I also have pictures posted that show the transmission fluid exchange and filter change.
1996 3.8L Windstar
