Go Back   Automotive Forums Car Chat > Mitsubishi > General Discussion
Old 05-06-2009, 11:25 PM
expo95 expo95 is offline
Starter Location
The car is 95 EXPO. Where is the starter located? Underneath the engine?
The car can not start. Turn the key to "start", I can hear a short clicking sound from somewhere, parking indicator is off. However, no crank sound, the headlight does not dim either. Replace the ignition switch, no help. Doubt Starter Solenoid is broken.
Old 06-09-2009, 01:14 PM
Asilus Asilus is offline
Re: Starter Location
The starter attaches to the flywheel on the engine, so depending on if its FWD, RWD it could be in diffrent locations. its usually 1 large cyclnder with a smaller cyclender under it. Usually when a starter goes bad the enternal gears dont grab anymore and as you crank you will hear a fast sounding spinning noise... turn on your head lights or your dome light and watch it as you crank and see if it dims down to almost dead, could possibly be your battery not having enouph charge to crank
Old 06-22-2011, 12:08 PM
katreen87 katreen87 is offline
Check with the fuel pump or the corroborator it might have gone faulty due to which you have the starter problem
Audi Parts
