Old 05-06-2009, 12:40 AM
phewop118 phewop118 is offline
3.5 Ticking
My 01 Intrigue (3.5L, 130k miles) has begun to make a ticking noise. At first, I thought it was low on oil, but that is not the case. The ticking is variable with engine speed and is much more noticeable between 1000-3000 rpm. Above that, it sounds perfectly smooth and revs to redline without any problems. At idle, it can't be heard, but if a load is put on the engine, such as turning the wheel while stopped, and the rpms dip a little, it is heard once again. I'm wondering if this could be the timing chain developing slack from years of full-throttle abuse. Or if it's lifter tick. Or even a small hole in the exhaust manifold? I know it's really hard to diagnose such an issue over the internet, but maybe if someone else has had similar problems, I would know where to begin looking.
Also worth mentioning is that the car sat all winter without being run. In late Feb. I had the waterpump replaced and now drive it about 200 mi per week. Finally, I don't know if it's related, but it seems to run slightly hotter now when cruising, with the temp indicator coming near the 1/2 way mark, whereas it used to stay exactly between 1/4 and 1/2 when driving on the highway.
Current Cars:
2001 Oldsmobile Intrigue GLS 154k miles
2005 Chevy Trailblazer EXT LT V8 145k miles
2005 GMC Yukon XL SLT w/Autoride 86k miles
2007 Pontiac Grand Prix GT 77k miles
2007 Cadillac DTS Lux II 47k miles
In Limbo:
2003 Oldsmobile Aurora 4.0 - got side swiped while parked, waiting on insurance decision
Recent Past:
2007 Hummer H3 5-speed Lease was over 7/17/10
Old 05-10-2009, 04:17 PM
Re: 3.5 Ticking
Nobody has any info to offer me???? I want to add that it seems to be consuming more oil than normal.
Current Cars:
In Limbo:
Recent Past:
Old 05-11-2009, 07:21 AM
canatto canatto is offline
Re: 3.5 Ticking
It could be exhaust noise. a cracked manifold or a snapped manifold mounting stud can produce a clicking sort of noise. Do you smell raw exhaust?
Old 05-11-2009, 06:03 PM
Re: 3.5 Ticking
Yeah I just noticed today while sitting at a red light that I could smell exhaust, even with the windows up. I'll do some poking around under the hood when I get a chance later this week.
Current Cars:
In Limbo:
Recent Past:
Old 05-22-2009, 06:58 PM
panzer dragoon panzer dragoon is offline
Re: 3.5 Ticking
I believe it's a pre-ignition condition since it's under a load. =knock sensor (not enough retard) is not working or a possible engine hot spot(carbon build-up -engine may "diesel" or keep running when you turn it off)
Should be burning up the carbon if you run it hard (you do) unless you burn a ton of oil. What is your oil use rate?
Old 05-22-2009, 07:05 PM
Re: 3.5 Ticking
Your burning of oil is creating hot carbon spots on your cylinder head. If I were you I would use an internal engine cleaner or de-carbonizer. I think Valvolene makes a good one at about ~$4. Add the whole thing to a full tank.
You may need to run a fuel injector cleaner ~$1-2 (it's cheaper) every tank or so after that.
Old 05-23-2009, 04:27 PM
dizzle1's Avatar
dizzle1 dizzle1 is offline
Re: 3.5 Ticking
It sounds like the valvetrain is sticky, also try seafoam
Old 05-24-2009, 01:55 AM
harmankardon35 harmankardon35 is offline
Re: 3.5 Ticking
one of the biggest complaints with the 3.5 is oil consumption, and that oil burning (especially if you make primarily short trips without warming the engine fully) will create carbon build up on all the valves, pistons etc. Too much carbon on the piston essentially makes less volume in the cylinder, causing higher compression which can lead to mild forms of spark knock or 'pre ignition', however a code scan is highly recommended to make sure your knock sensors are in good shape. Sea foam (as mentioned) is very good advice. I love the stuff.
Old 06-20-2009, 07:41 PM
Re: 3.5 Ticking
I'm beginning to think that this is definitely an exhaust leak. I can now smell exhaust when the car is sitting still or when the windows are up and I'm driving. Also the noise is getting somewhat worse and is similar to the sound it made when there was a hole in the resonator, except that the noise is coming from the back, driver's side of the engine. If it is indeed the rear exhaust manifold, I may just get rid of the car, as it is quite an expensive repair and the car is getting old.
Current Cars:
In Limbo:
Recent Past:
Old 06-20-2009, 08:56 PM
Re: 3.5 Ticking
an exhaust leak on just one cylinder (headers) will cause a ticking noise, an exhaust leak anywhere past that will give you more of a steady sound.
Old 06-21-2009, 02:59 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: 3.5 Ticking
Since you say youre smelling exhaust, I agree with the others, probably an exhaust leak, which leads me to the following:
Do you have emissions testing where you live? The reason I ask is thats the only reason I can think of why you would get rid of it because of an exhaust leak.
I mean...its an exhaust leak, its not a automobile crippling malfunction.
Not trying to sound like a jerk, but just seems like a strange reason to get rid of a car. But like you said its a little old I guess, not quite ten years yet, but I mean in reality you could probably get another 50,000 miles or so out of the thing. I come from the type of folks who often drive cars until the wheels either figuratively or literally fall off, so you can see why I ask the question.
Bottom line, its your car, and you can do whatever you want, its a free country...for now.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 06-21-2009, 12:53 PM
Re: 3.5 Ticking
Yes, in pa there's emissions testing. Otherwise I would have no problem keeping the car in it's current condition. It's due for testing in august, but I think it might pass emissions, as pa has a new law that only requires a computer check for codes. However, it would fail the state inspection, which is very comprehensive and stringent. I'm still looking around, but it might be about the same price to buy an LS4 engine and transmission from an Impala Ss or Grand prix gxp as it would be to buy and replace the rear exhaust manifold. Of course this would be a huge undertaking and much of the work would have to be custom, but I don't really need to drive the car anymore, so I could drag it out over some time.
Current Cars:
In Limbo:
Recent Past:
Old 06-22-2009, 01:17 AM
LittleHoov's Avatar
Re: 3.5 Ticking
Yeah I figured there was some emissions stuff involved.
An LS4 would be sweet, but like you said entirely custom.
An L67 swap would be a lot more feasible, and pretty capable even bone stock, add in some mods and you can go faster than anyone really NEEDS to go haha
Old 06-23-2009, 08:33 PM
Tobey Tobey is offline
Re: 3.5 Ticking
My 2000 has been doing this exact same thing for the last year. I've been meaning to post about this for a while. The ticking mine is making also seems to be coming from the rear of the engine towards the drivers side. It also becomes extremely noticeable if the engine is idling while under load (in gear, AC compressor on).
I always thought it was an exhaust leak, but today I did some investigating by running water over the exhaust manifold while the engine was running (while it was still cold of course) and I didn't see anything.
I took the plastic cover off the engine and immediately noticed the noise seems to be coming from all 6 cylinders. I'm thinking it's the lifters. At first I thought it was the injectors, but there's no way an injector could make this amount of noise.
