Old 05-05-2009, 06:25 PM
DRKWING2 DRKWING2 is offline
Fuel Pressure
99 Silverado 5.3, wondering what fuel pressure should be while running. I understand that key on engine off is 55-62 psi.
Old 05-06-2009, 09:10 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Fuel Pressure
55/62
Pressure will vary to engine vacuum load.
Any running or starting problems?
5.3 has a lot of problems with fuel pressure regulators.
Specs on it is 55/62 lbs of pressure
Here is some guide lines of fuel pressure checking.
Hard to start cold.
Check cold start fuel pressure.
Check engine running fuel pressure.
Check engine running on the road fuel pressure.
Then shut it off and watch for fast leak down.
Pinch off at rubber part or block off return line and check full pressure.
Later V6 and V8 gm engines should have 55-66 fuel pressure.
Cold start should be 55/62 lbs of pressure.
If you do not have full fuel pressure on a cold start the injectors will not squirt fuel.
Do not leave home without it.
Engine running should be 55/62 lbs pressure depending on engine load.
Full pressure with return pinched off should be 75-85 or more.
And if it has a fast leak down after shut off you have a leak.
If pressure does not come up with return line pinched or blocked off.
Go to fuel filter and hook a gauge direct to a line at fuel filter.
Pressure should come up to 75 or more and will hold after fuel pump is turned off.
If it leaks down there after fuel pump is turned off it is LEAKING BACK THREW PUMP CHECK VALVE OR PUMP MODULE LINES.
Post back your fuel pressure readings.
MT
MT
