Go Back   Automotive Forums Car Chat > Buick > Terraza
Old 05-05-2009, 06:22 PM
Ray Layne Ray Layne is offline
Cool 05 No Ac Air on Driver's Side Vent
O5 Buick, Terraza will not blow AC cold air on driver's side. I believe the problem may be the blend door actuator or blend door. Has anyone experienced the same problem.
Does anyone know whether the dash must be removed to replace the blend door actuator?
Old 11-30-2010, 06:48 PM
ddotj3 ddotj3 is offline
Re: 05 No Ac Air on Driver's Side Vent
i have the same problem and yes the the dash has to come out. I found that if you if you roll the drivers side to cold and then passenger. then roll drivers side back then passenger side it works, good luck
