Old 05-05-2009, 08:27 AM
gbeach gbeach is offline
how to remove sliding door behind driver
got hit in driver side sliding door. does anyone know how it comes off.
1998 dodge caravan
Old 05-05-2009, 08:03 PM
Honda_12 Honda_12 is offline
Re: how to remove sliding door behind driver
SLIDING DOOR
CAUTION: Apply several layers of masking tape to the body around the rear end of the upper roller channel and the forward edge of the quarter panel, to avoid damaging the paint.
REMOVAL
  1. Apply masking tape to outside surface of quarter panel below the center roller channel, rearward of the door opening.
  2. Release sliding door latch and open door.
  3. Apply masking tape to door jamb area, rearward of the upper roller channel.
  4. Remove screw holding upper roller arm stop bumper to upper roller arm Sliding Door Upper Stop
  5. Remove stop bumper from upper roller arm.
  6. Remove center stop bumper trim cover from sliding door Sliding Door Center Stop Bumper
  7. Remove center stop from sliding door.
  8. Remove sliding door sill plate.
  9. Remove hold open latch striker Sliding Door Hold Open Latch Striker
  10. Open quarter glass.
  11. Remove center roller channel end cover Center Channel End Cover
  12. Support sliding door on a suitable lifting device with a padded upper surface. The door must be moveable with lifting device in place CAUTION: Do not allow the center hinge roller to contact the quarter glass. Glass can break.
  13. Roll door rearward until lower rollers disengage from lower channel.
  14. Roll the door rearward until the upper Sliding Door Upper Roller and center hinge rollers exit the upper and center channels Sliding Door Center Roller
  15. Remove sliding door from vehicle.
INSTALLATION
  1. Place sliding door in position on lifting device.
  2. Position door rearward of the sliding door opening CAUTION: Do not allow the center hinge roller to contact the quarter glass. Glass can break.
  3. Engage the center hinge rollers into the center channels Sliding Door Center Roller
  4. Roll door forward until lower rollers engage into rear of lower channel.
  5. Engage the upper hinge into the upper channels Sliding Door Upper Roller
  6. Install hold open latch striker Sliding Door Hold Open Latch Striker
  7. Install sliding door sill plate.
  8. Install center roller channel end cover Center Channel End Cover
  9. Install center stop on sliding door Sliding Door Center Stop Bumper
  10. Install center stop bumper trim cover on sliding door.
  11. Place upper roller stop bumper in position on upper roller arm.
  12. Install screw to hold upper roller arm stop bumper to upper roller arm Sliding Door Upper Stop
  13. Remove masking tape from body surfaces.
  14. Verify door operation and fit. Adjust as necessary.
this is for the blue lettering in order (sorry couldnt find that many pics)
hope this helps
my friend is a dodge mechanic with a webiste were he can get diagrams and instrusions
Old 05-06-2009, 12:05 PM
thanks honda12, i appreciate it.
Old 05-08-2009, 02:18 PM
no problem its waht i do when im bored
