Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-04-2009, 11:43 PM
Ia_Wolfpac Ia_Wolfpac is offline
Unhappy 91 Formula wont start-no gas
I have a 91 tbi 5.0 v8. After rerunning some vaccum lines from the heater/AC controls and fixing some wiring I'm not getting any gas in the engine. I can hear the fuel pump start when I turn the key on but no gas in the carb. When I dump a little gas in carb it fires off fine? I also put a new fuel filter in. Any help would br great.
Thanks in advance for your help
Old 05-05-2009, 01:06 AM
Morley Morley is offline
Re: 91 Formula wont start-no gas
Hook noid lights up to the harness in place ofthe injectors and crank the engine. Look for the lights to be flashing. If they don't flash then the ECM isn't seeing the refrence pulse from the distributor and won't fire the injectors. Look under the dash for any wires you may have broken or pinched.
Old 05-16-2009, 02:05 PM
stetzz05 stetzz05 is offline
Send a message via AIM to stetzz05 Send a message via Yahoo to stetzz05
have you made sure getting fuel to the tbi? check pressure at the line to the injector
