Old 05-03-2009, 10:17 PM
s tinner s tinner is offline
83 2.0 to 85 2.5 swap
I have an 83 s-10 2wd with a dead 2.0 4cyl . I have a running 85 2.5 motor a friend gave me. I have changed motor mounts,gas tank and im in the process of mounting comp and trying to get everything to work.I need help with the hydraulic clutch on the 2.5 I need ideas on what to do since the 2.0 was a cable clutch. I dont think the tranny from the 2.0 will mount up to the 2.5 so I thought I would ask questions now and see if anyone has done this swap before.Thanks
Old 05-03-2009, 10:54 PM
Re: 83 2.0 to 85 2.5 swap
I think instead of a 2.0 its actually a 1.9 that was in it .....
Old 05-16-2009, 09:18 PM
SuperTen's Avatar
SuperTen SuperTen is offline
Both Standard Trannies... If so they should match up.. The only thing that is different is the Motor sizes.. The holes where they site are the same size.
