Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 05-03-2009, 08:29 PM
eric1h eric1h is offline
Carb recommendations?
I am converting the LS1 over to a carb setup and wanted to get some feedback for a good road race capable carb, trying to stay @ $550-ish if possible
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 05-03-2009, 11:02 PM
panozracing's Avatar
panozracing panozracing is offline
Re: Carb recommendations?
The barry grant mighty demon worked great for us.....
We used holly's too... Had sucess with both...
I might be selling 2 barry grant's...hmmmm
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 05-04-2009, 09:13 AM
ANyone have experience or heard of anything about Proform?
This one looks appealing, from a feature function and cost perspective...
Proform 67205 750 CFM HP Race Series
Old 05-04-2009, 08:34 PM
NZGTRA17 NZGTRA17 is offline
Eric, I also use Barry Grant Mighty Demons. I have had very good success and no problems using these carbs on the last 2 cars that I have raced. I have used 650 Mighty Demons on both and my last car was a 460 RWHP 5.0 liter.
I have used Holleys in the past and also had few issues with these. Bottom line for me for going with the Barry Grant was getting most of the desirable 'custom race carb' features at a massed produced price. If you have an excess of cash for a custom carb then this may work better for you.........
With the 5.0 in my Panoz we tried both the 650 and a 750 Mighty Demon on the dyno. The 750 did not yield any Hp or Torque advantage so we stayed with the 650. Being a little larger you engine may like the bigger carb but only the dyno will tell you this for sure.
One thing to look out for with Barry Grants is to ensure that the threads for the air bleeds in the air horn of the carb have been formed properly. I have experienced where these threads have not been formed properly at the factory and a bleed has dropped out of the carb as it had nothing to hold it in. Not great if it gets sucked into your engine!! Otherwise no other quality issues that I have struck.
You may read on other forums where people say they have not been able to get a Barry Grant to run properly on their engine. I cannot see how this could occur unless the tuner is not adequately trained. We have never had this experience as with appropriate jet and bleed changes we have been able to get satisfactory raceability. As with any race engine you definitely need to dyno tune the set up to adjust the carb properly.
I am interested to see how your carbed LS1 goes as I like the Edelbrock kit for this conversion, particularly the Victor style kit for road race applications which I guess you will opt for?
Kel M
Panoz GTRA #17
New Zealand
Old 05-12-2009, 10:29 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
We've used a pro-systems on our 5.0 build... it was just under a $1000 though.
Old 05-20-2009, 07:37 PM
Brian, have you done any road race specific modifications to your BG Mighty Demon carbs (i.e. jet extensions, different floats or other)?
Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 05-20-2009, 08:01 PM
NOPE! not needed! Actually I am not totally sure. We gave them to my engine builder and he tuned them. If he did anything it didnt cost much? I can ask if he remebers if you need to know.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 05-20-2009, 08:06 PM
I am curious Brian as we seemed to get a reasonable amount of fuel bowl surge into and out of fast corners that was causing puffs of black smoke out of the exhaust as the throttle was modulated on entry and exit.
Kel.
Kel M
Panoz GTRA #17
New Zealand
