Old 05-03-2009, 07:07 PM
slimm22 slimm22 is offline
Exclamation 2000 Trailblazer Ticking Sound
I have a strange problem going on. I replaced the head gaskets on my 2000 Trailblazer 4.3 (4X4), and now it has a ticking sound when I first start it, but after it warms up the ticking stops. And I also have a Cylinder 1 Misfire code that keeps coming up. Please Help, cause I'm in the process of giving it to my mother, but have to fix it first.:ban ghead:
Old 07-05-2009, 11:18 PM
Kamann Kamann is offline
Re: 2000 Trailblazer Ticking Sound
piston slap happens at cold start-up due to lack of oil in the top end of the engine...very common in Chevys
Old 07-15-2009, 10:31 PM
jyount jyount is offline
injectors could be noisy.
piston slap is probably your noise, they have had a couple lifter problems also, not many though. Listen with stethescope to 1 if that is misfiring...could be lifter, probably fuel or fire though.
I assume you meant 4.2....
I have worked on a few of these that mice have gotten to the injector and coil wires, don't know why, but they seem to like trailblazers if they are available
Other than that, swap coils with 2, then swap injectors with 2, see if it follows either....
Contrary to what STP and others make a fortune on, if your injector is stopped up the ONLY repair is to replace or have it rebuilt, They are very small orifices and stop up. The coil part of it can go bad too...
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 07-15-2009, 11:21 PM
noticed 2000, maybe that is a 4.3, trailblazer like the package of a blazer right, not a "trailblazer"
Still same applies, except they are not known for piston slap, check the oil cap, see if you have antifreeze in the oil making lifter noise...
They are well known for intake leaks, but they leak externally not internally.
As for the fuel system, you cannot swap em, the fuel manifold is an assembly on those things, have to pull the upper intake to get to em too. As for a miss on 1 check the plug wires and plug, not uncommon ESP on aftermarket wires. I guess those little v6s have alot of heat soak around the plug wires.
Current job: RN
Wife's
