Old 05-03-2009, 10:18 AM
msusscle83 msusscle83 is offline
changing tranny oil/fluid?
Hey Guys,
My 00 GP GT just hit 100k. I got her with 79K and I know I never changed any of the tranny fluids, but I'm not sure about the prior owners. I do not have any tranny issues (knock on wood), so I was wondering if you would recommend I changed the fluid for regular maintenance now? Thoughts? Some people told me that if you change around 100k and never did so before you can encounter tranny problems afterwards, so I'm not sure how true that is....Thanks as always!
Old 05-03-2009, 10:27 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: changing tranny oil/fluid?
I did a pan drop and filter replacement around 85,000 on mine. No issues afterwards.
I think if you do a pan drop and replace the filter you'll be fine. No flushes!
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 05-03-2009, 01:28 PM
rev2red's Avatar
rev2red rev2red is offline
Send a message via MSN to rev2red
so no flushes? I have 70,000k on mine and it seems to be shifting kinda hard while upshifting
Old 05-03-2009, 01:44 PM
tblake's Avatar
In God We Trust
Yep, no Flushes.
Rev2red, I recommend you review this thread at the tips and maintenance subforum. It might be a good time for this type of mod. (probably for the OP also)
http://www.automotiveforums.com/vbul...d.php?t=920671
Old 05-03-2009, 02:03 PM
rev2red's Avatar
thanx, i will go get a scan done asap!
Old 05-03-2009, 02:20 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
just as an additional pointer...if you decide to put in a shift kit alot of them have "firmness settings" when i bought the shift kit from ZZP it had 3 different spacers you could put in.
i suggest that you DO NOT put in the largest spacer...just use the middle sized one.
Old 05-03-2009, 09:50 PM
wafrederick wafrederick is offline
Banned
The valve body might have come out for a throught out cleaning.I know a transmission shop in my area that does lots of valve body cleanings due to flushes with the machine.
Old 05-04-2009, 01:32 AM
tblake's Avatar
In God We Trust
If he doesnt get it flushed, he wont have to get the valve body cleaned. Its best to leave well enough alone unless there is a problem. (especially inside the transmission).
Just run seafoam trans additive in it for a week, do a pan drop, install the medium shift kit from ZZP a new filter, and refill with fluid.
