Old 05-02-2009, 09:28 PM
green-giant32 green-giant32 is offline
95 grand am turn signals
my 95 grand am turn signals arent working inside or outside of the cab... i changed the fuse for it but its still not working, any suggestions for someone with basic car skills?
Old 05-03-2009, 01:36 AM
3100 3100 is offline
Banned
Re: 95 grand am turn signals
test turn signal flasher (round looking part) right of the steering column
Old 05-03-2009, 01:38 AM
how would i test that?
Old 05-03-2009, 11:08 AM
Banned
let say there are 4 pins a, b, c, and d on you flasher. measure resistance between ab ac ad
bc bd and cd write measurements on the paper and go to autozone and do the same on the new one before you buy it and compare the results. If you get close readings you are ok if not you need a new one.
Old 05-03-2009, 11:20 AM
awesome... thats really good info... but just 2 more questions so far... what should i use to test it, and along the steering column inside the cab i take it?
Old 05-03-2009, 11:51 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Welcome to AF green-giant32 !!
Yea the flasher relay is in the cabin area. Should be a small round cylinder looking thing close to the steering column with 3-4 wires running to it.
Btw hav you tried your hazzard lights ?
If they work and your turns dont, then your multi function switch is most likly the problem.
1999 Grand Am SS 3.4 OHV
Old 05-03-2009, 12:02 PM
hazards also arent working... but yeah, i'll give those a shot as soon as i figure out how to test it exactly lol
Old 05-03-2009, 04:49 PM
Ok, if the hazzards arent working then it's most likly the flasher relay thats bad.
Might as well replace it, as it's not worth trying to test.
The new one will be sealed in a package and once you open it you cant usualy return it, they are inexpensive.
Here is a pic of where it's located....
Old 05-03-2009, 05:13 PM
this is the best forum i ever came across, thanks, i'll take a look at it shortly and go buy a part tomorrow
Old 05-03-2009, 05:49 PM
i've got the part... turns out Lordco is open on sundays, i'll change it in a little bit and let you know if it worked
Old 05-03-2009, 07:23 PM
unfortunately, i've pulled the lower part of my dash down... and then a metal plate down... and the section your picture shows is held in by rivots or would take a lot of effort to pull apart... then i probably wouldnt be able to get it back together... anything i'm missing?
Old 05-03-2009, 08:15 PM
so i eventually found it after i started putting stuff back together, i found a few pictures on gaownersclub.com that helped me finish finding it, my hazards dont work but thats another problem for another day lol, thanks guys
Old 05-04-2009, 10:20 AM
Banned
just looked at the electrical diagram for your 95 3.1 and realised that your hazards have their own flasher, and turn signals have their own flasher as well. It is very unlikely that both failed at the same time, and you said that fuses are all good. So if someone did not do some work around the multifunction switch and leave connector for turn signal and hazard swithc disconnected then I think you have MFS problem. But since you got the part try it anyway but I doubt that it is going to solve the problem this time. It is one of this two for sure( bad connection to MFS or bad MFS).
Old 05-04-2009, 10:43 AM
well the relay fixed my turn signals... so i think the switch is probably ok
Old 05-04-2009, 12:00 PM
Banned
good work,
but strange, XI please check Mitchell's and see if they show two separate flashers, Alldata shows one for turn one for hazards for 95 model
