Old 05-02-2009, 04:31 PM
wayne64 wayne64 is offline
Trailer wiring 96 S10
I finally added a rear hitch to the Blazer and would like to know where is the easiest place to grab my feeds for the flat 4 wire connector. BTW I'm also going to weld up a front hitch point so I can park my boat in the tight driveway. TIA
Old 05-03-2009, 08:40 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Trailer wiring 96 S10
Where ever there is a good clear open space to tap into the rear tail/brake/turn signal wiring.
Always use wiring code
Yellow = left turn
green = right turn
Brown = tail/park lights
Car wiring uses black for ground and trailer may use white wire for groud.
I like to use trailer plug white ground wire grounded to frame ground.
If you splice in trailer plug always soldr wires and use moisture sealer to seal wires.
No quick connectors.
A lot of places have a trailer wiring kit that will plugin to the rear frame wiring.
Easy install and Saves butchering your wiring.
Let us know how it goes.
Good Luck
MT
Old 05-03-2009, 09:34 AM
toddman67 toddman67 is offline
Get a Hoppy trailer wiring adaptor which will plug into your existing weather pack connector at the rear of the truck.
Part#47345....about $11.00.
Old 05-03-2009, 04:17 PM
Thank you, for the info folks. BTW a 96 doesn't have an easy plug in you have to tap in. But I found though a search of Hoppy kits installation PDFs and the harness should be drivers side behind bumper. When it stops raining I'll climb under to check.
