Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-01-2009, 11:48 PM
sgbuick sgbuick is offline
Wider tires in back
On 96 Caprice, I currently have 215/75 R15 tires which are apparently very hard to find. I have 2 nearly new 235/70 R15 tires sitting in my garage from a previous Buick Roadmaster, can I put them on the back? If I do, will it cause any issues?
Old 05-02-2009, 12:06 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Wider tires in back
It might mess your speedo calibration a little but it should otherwise work.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-02-2009, 09:13 AM
Blue Bowtie's Avatar
Registered Offender
215/75-15 should have a circumference of 87.012" whereas a 235/70-15 should be 87.816". That will decrease the speed indication by a factor of 0.99079, or less than 0.09 percent.
Old 05-02-2009, 03:11 PM
So, other than the speedo being off a little, everything else regarding ride/handling should be OK?
Old 05-02-2009, 06:23 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
You might notice a slight increase in understeer during hard high speed cornering (if you do that sort of thing.) But for regular driving, you should be fine.
Just take a peek in the rear wheel wells and make sure the wider tires will not rub when the suspension is compressed. I seem to recall Caprice cop cars used 225's or 235's and were just fine.
Old 05-02-2009, 10:58 PM
Yeah, the tires I am talking about came from a 96 Roadmaster, which has enclosed wheel wells (fender skirts), so I am guessing that they would not rub on a Caprice with open wheel wells?
Old 05-03-2009, 09:00 AM
MagicRat's Avatar
I did think of that, too. IMO put them on and just take a quick look. If you do not see any obvious interference, imo you are good to go.
Old 05-06-2009, 12:26 PM
j cAT j cAT is offline
since these other tires are greater in circumference be cautious when driving in speed restricted areas as your speedo will read lower speed than you are actually going...
don't want a speeding ticket....
