Old 05-01-2009, 07:10 PM
tempfixit tempfixit is offline
93 BCM location
Can anyone tell me where the BCM is located in a 93 Plymouth Voyager??
I know where it is on a 94 but cannot find it on the 93. One place I haven't looked yet is behind the glovebox.
The online manual or my haynes manual or autozone.com shows it's location.
Thanks
Old 05-02-2009, 02:43 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 93 BCM location
Bottom of center console on the floor??? Maybe on the back of the junction block as on gen 3s ???
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 05-06-2009, 03:58 PM
Re: 93 BCM location
Found it:
93 BCM is right of steering column, between steering column and heater control, heater control level> Remove the knee panel below steering column. (The BCM is attached to body with 2 sheet metal screws.)
94 BCM is right of steering column, center of dash on the floor. Remove the storage compartment from floor to ashtray. The door lock and unlock relays are also located in same area. (The BCM is attached to body with a larger lag screw with I believe a 10mm head.)
QUestion: I have read that BCM numbers should match, is this true on the second generation vehicles also, and do they need to be reprogrammed or flashed. The 94 BCM number is really hard to read, hopefully i can swap these BCM's and have door locks. ( The 94 BCM has power at the input of door lock but not the output for door locks at the BCM) The door locks did work on the 93.
Thanks Rip for reply and any other advice you or any one else may have on this issue.
