Old 05-01-2009, 05:56 PM
deaaa deaaa is offline
98 gc fans not working.
I have a 1998 GC with a 3.8, both fans do not turn on. I even tried turning on the A/C then tried the Def. and the fans do not come on. I checked the 40A fuse and changed it out with another one, no good. I then checked the fans with a 12V battery, they work. Is there another switch or fuse I missed?
Old 05-02-2009, 02:54 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 98 gc fans not working.
9 of 10 times the fan control relay is the culprit. It's mounted on the frame to the driver's side of the radiator under the air intake box. Follow the harness from the fans and you'll find it. Disconnect it and jumper contacts with the grey and dark green wires. Don't need the key on. The fans should turn on. This checks additional wiring and the fans you've already tested. If all is well change the relay - around $50. On rare occassion the PCM won't supply the required modulated power to the relay. PCM is around $350. $600 at the dealer.
A binding fan bearing can fry a relay. Spin each by hand and make sure they turn freely.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 05-02-2009, 10:57 AM
A thanks for the info. I changed out the relay, and the fans now work, thanks again for the help. I will check the fan bearing .
Old 05-02-2009, 01:08 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Thanks for giving the fix. Happy to hear all is well.
