Old 05-01-2009, 04:00 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
What it it really about?
well, i decided to share my view of what exactly the "dsm bug" does to me... i would be interested in comments, and reading your guys versions of why you choose to build a DSM...
***I do not participate or encourage any form or reckless driving or racing on public roads. This is a story merely to express my emotions and feelings about the connection i have with my car***
"It is about the love for the clean and yet distorted reflection of yourself in the paint, the tones and vibrations from the engines as the RPMs climb up the tack, the sound and smell of the tires and they melt into the pavement. It is like a drug. The farther you push the car, the faster the RPMs climb, the harder your body is pressed into the drivers seat, the more ecstasy it releases into your body, then as you familiarize yourself with the her, the dose seems to wear thin, what was once an overpowering sensation of speed and power, has become noting more then a "quick high"...
Money is tight, you have worked hard for what little you have. Now comes decision time, food/bills/rent/save/etc... or... as many of the next few pieces that money will allow to bring that ecstasy back... with out a doubt in your mind, the moneys spent. Once you receive world the parts have arrived, you drop everything and the entire world becomes obsolete while you are under the hood, now closer then ever to her. It almost seems like you can close your eyes, the car will guide the wrenches into place. Because she wants to be built, she wants to gain strength; she needs it and craves it just as much as you.
Hours pass in what feels like minuets, your blood and sweat have mixed with the cars oil and grease, bringing you truly together as one. Upon completion, you stumble in from the garage, so tired you can barely stand, after a full day of class, followed by work, then the several hours in the garage... class starts soon… and you are in need of sleep. The clock reads 5am as you wash the dirt and grease off of your hands, again, it is decision time... some well deserved rest... or... Test drive... if you have come this far, you choose the obvious.
As you turn the key, the starter engages, you can hear the wine of the fuel pump from behind you, the crank is turning, and the plugs are hot. Just as you release the key, she fires, and fills your ears with the sweat sound of success, allowing time for her to awaken, you walk around the rear of your car, admiring her beauty as you approach the front from the passenger side, pause directly in front of the car, for one final look at your hard work before experiencing pay off. Gently close the hood, more excited then tired at this point. As you back down the drive way and into the street, you find yourself aware, more awake then ever. you cruse out of the neighborhood keeping her as quiet as you possible, respecting the fact that it is 5am, and the neighbors are asleep. Once you can see the main road, and your heart beat grows faster, as you pull up the final stop before the open road, you heart is pumping out a steady match to the tachometer on the dash. You and your car are together as one.
Your left foot falls in firm contact with the clutch peddle, as you press it to the floor, your right hand slips the shifter into first gear, smooth as butter. You ease the throttle, and feel your heart race even faster. You turn your attention to her, idle is right on the money, air/fuel ratio is perfect; logger is live, and active. She is ready. You take one last deep breath, knowing the next few seconds will forever change you. Your right foot creeps onto the gas peddle. The RPMs shoot up, the launch control engages holding the Motor at a strong 5500 rpms as your eyes leave the dash, and you gaze down the street. You let off pressure on your left foot. The clutch catches the flywheel, and the tires begin to slip. You lean into the throttle. Steady and strong she climbs through first. The roar of the exhaust is deep, and rich. The spool of the turbo is fast and strong. As you shift to second, the blow off valve flutters. The car lets out an excited pop as if to thank you for the added strength.
The car pulls harder in second as the boost comes on, pressing you into the seat harder then ever before. The feelings build with each revolution of the engine. As the RPMs climb, complete ecstasy overcomes your body, your mind, and your soul. As you reach the top of second gear, another decision time though more directed by instinct than consciousness … dare you continue into third… or… are you satisfied with this does? Before that very thought can register in your mind, you have already completed the shift, and are back on the gas. The engine screams with joy under wide open throttle and the turbo spools to full boost. By the time the wastegate opens, its too late, you’re already gone. Encased in this ecstasy you have created, you hit forth gear and are traveling over twice the posted speed limit; however, you are still steady, and sure. The rpms match the needle on the speedometer, as you climb into a world unknown to most. 140mph, 150mph, you let off.
The blow-off valve bursts open, the engine whines down, popping in thanks on the way. You come to a stop. Your sweating, breathing is heavy, eyes watering, hands are shaking. Success, The ecstasy is back. You return home in pride, knowing all the money and time that was spent, was well worth the benefits. Upon arrival, you pull into the garage and park. Close your eyes, and re-imagine the run in your head. Shut her down, remove the key, and get out of the car. As you enter the house, you look back over your shoulder at the beast you have built. Nothing needs to be said, you already made the decision to continue your build, to continue to push the car past the points or logic. As you climb into bed, you think to yourself in a dream like way, if only it was even FASTER"
Old 05-01-2009, 07:07 PM
steviek's Avatar
steviek steviek is offline
Re: What it it really about?
I'm not goign to lie I've done things on the street. I know there's a time and a place for it and I think that has been why I don't even get so much as a speeding ticket rather than an accident.
I love the feeling of being able to take a car with a ticket value of 4 or 5 times mine. The only difference being that I poured my soul into and he drove it off the lot. I don't hate people who by 100k cars I love them too I just love seeing the look on their face. My car I chose after tons of research. I knew its potential and its limitations. I loved the way ahead of its time styling and I was even more attracted to the domestic/import meld which essentially provided the best of both worlds. I love the community except for the know it all guys who thing its only there way or its stupid. Or people who nit pick about stupid things and make a big deal about something thats not.
Example in my head gasket thread on link forums a bunch of guys were crying that I held up the head using an engine hoist from one of the bolt holes. It of course did no damage at all but they all had to throw in their two cents about how they just lift the head off etc. I said why work hard when you can work smart. I love how my friends respond when they've taken a ride in my car Now one guy I know is swapping a 4g63 in his avenger and another bud is buying an evo because he loved the awd launch and turbo (originally planning on getting a cobra).
My car is mine and the freest I've ever felt is driving it on the open road with the windows down and the sunroof open screaming with the music as loud as I can!
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 05-01-2009, 10:10 PM
Black99GST's Avatar
lol pretty sure we all have ... and some of us still do, and will continue to do so ... but being aware of your surroundings, the road condition, and the other lives at risk pays a big part in being smart about it.. i just put that in their, so im not responsible if anyone (especially the younger guys) read it, and then go and kill themselves, or worse, someone else, trying a 150mph pull down a city street...
EDIT: just like your 4.01 sec 0-60 video steviek... i believe it was something like "performed by a Canadian on a closed course with houses on the side of the course in Mexico, or Canada..."
Old 05-01-2009, 10:42 PM
gstclips gstclips is offline
Send a message via AIM to gstclips
I chose dsm cause chicks dig em...
THE OFFICIAL AF PIMP! - love EclipseRST[Banned]
1997 Gs-t Eclipse
6 bolt + other toys
Currently 295whp
Old 05-01-2009, 10:50 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Black - You seem to have hit it perfect. And the fact that I took a car that was balls slow and have tripled the whp output. It feels good to say I built that motor and tuned it myself. I was on the way home today from school and just couldn't resist doing some 3rd gear pulls. I love to feel the car pull so hard on the highway.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 05-01-2009, 10:55 PM
steviek's Avatar
hmm something like that
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 05-01-2009, 11:34 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Haha. Nice write up. Thats exactly how I USED to feel. Kinda growing tired of it all. Probly just because I don't have the money to really go to the next level, so, stuck with a almost quick car, and I've grown immune to anything that isnt insanely fast. So....I drive a civic everyday.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 05-02-2009, 12:23 AM
Holset powered 420a
This part sucks. I crank up the boost a little and the car feels good for a few days then gets boring and I want more power. I dont think its ever goin to end. My car doesn't feel like it pulls all that hard anymore.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 05-02-2009, 09:44 AM
steviek's Avatar
Originally Posted by silvreclipse View Post
this part sucks. I crank up the boost a little and the car feels good for a few days then gets boring and i want more power. I dont think its ever goin to end. My car doesn't feel like it pulls all that hard anymore.
agreed 100%
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 05-02-2009, 02:48 PM
Man Im telling you, when I first turboed my car....its was soooo fast. It was stoopid fast. And everyone knew it. I was the S***. Then other people around me started stepping up to the plate. Before I knew it I was elbow deep building a 13.4 e/t bolt on SRT4, a few 12 sec 6.0 GTO's, a 7.3 sec (1/8 mile on street tires) z28 camaro, etc, etc. Not to mention one of the guys stepped up and got the new z06 and he's doing work to it.... scary fast...
Ive been lucky enough to be a big part in working on alot of really nice and fast cars....but its not the same.
When I was younger and was building my spyder....there was no better feeling in the world. So much pride, joy, satisfaction, enthusiasm, dedication....its indescribable....words dont do it justice. I was on top of the world.
I need to feel that again...
Caleb
vanilla gorilla
Old 05-02-2009, 10:03 PM
Black99GST's Avatar
changed up the ending... just seems to really hit the nail on the head even more.
Old 05-02-2009, 10:59 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Agreed...
I got into the DSM scene after riding in a completely built one that ran low 11's... I lost my load in that car on the streets... I had to get one... And let's not forget the BA sounding BOV that made everyone on the streets know your presence.
I miss it so much...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
