Old 05-01-2009, 05:38 AM
deb0704us deb0704us is offline
Send a message via AIM to deb0704us Send a message via Yahoo to deb0704us
Emissions Test Failure
My friend has a 2003 Grand Prix. Took it for emiissions test. They told her the "torque converter clutch circuit" is stuck on. What the heck is that, and is it expensive to repair?
My New Vehicle:
2008 Grand Prix GXP
Crimson Red ~ 4 Door
8 Cylinders All Mine
It's Loaded!
I'm Lovin' It!
Former Vehicle Totaled in Crash:
1998 Grand Prix GT
Bright Red ~ 4 Door
Old 05-01-2009, 07:04 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Emissions Test Failure
It could be expensive if it requires removing the transaxle side cover or rebuilding it. Do you have the specific code (DTC)? What it means is the torque converter clutch is possibly stuck to the on position and not turning off when commanded to do so. The TCC is supposed to cycle on and off depending on the driving conditions and what gear the car is in.
Timeslip 08/12/06
AF Community Guidelines
Old 05-01-2009, 07:25 PM
Yes, they did give a DTC code : PO742.
My New Vehicle:
2008 Grand Prix GXP
It's Loaded!
I'm Lovin' It!
1998 Grand Prix GT
Bright Red ~ 4 Door
Old 05-02-2009, 07:58 AM
BNaylor's Avatar
In order to set the P0742 DTC the PCM module has detected that the TCC release switch is closed when the TCC is commanded off meaning it has detected it is actually stuck on or open. The TCC release switch is part of the automatic transmission fluid pressure manual valve position switch (TFP) which is located on the valve body.
So the first step is to check ATF level. Next step with engine off is to remove the 20 way electrical connector at the transaxle and reseat it. Next step if the transaxle hasn't been serviced recently is do a pan drop service and replace the ATF and screen filter. After that major transmission service will be required.
Timeslip 08/12/06
Old 05-02-2009, 09:12 AM
Thanks BNaylor! I'll let you know what the outcome is soon. Thanks again!
My New Vehicle:
2008 Grand Prix GXP
It's Loaded!
I'm Lovin' It!
1998 Grand Prix GT
Bright Red ~ 4 Door
