Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 04-30-2009, 09:52 PM
bigdaddy6 bigdaddy6 is offline
cant start after locking keys in
my wife locked her keys in the car we broke into car alarm went off got keys out now the car wont start
Old 04-30-2009, 11:21 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: cant start after locking keys in
Did you try locking and unlocking the doors with the key?
Old 05-01-2009, 06:32 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Is it a factory alarm or an aftermarket system? Does the 'Theft' or 'Security' light in the instrument cluster flash, stay on constant, or not come on at all? What year is your LS? Does the engine crank just not start, or doesn't even crank?
-Rod
Old 05-02-2009, 10:21 AM
the car does crank but wont fire the security light blinks like crazy it is a 2000 ls 3.0
Old 05-02-2009, 05:59 PM
shorod's Avatar
SHO No Mo
Assuming you've tried the suggestion offered above by Airjer, do you have a second key that you can try? The blinking Security light would be a good sign the no-start is due to the anti-theft system.
If you have access to a professional scan tool, you can pull the codes for the anti-theft system. You might also try leaving the car battery disconnected for 15 minutes or so to see if that will clear the fault.
-Rod
