Go Back   Automotive Forums Car Chat > Kia > Rio | Rio Cinco | Pride
Old 04-30-2009, 10:30 AM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
Changing '03 Rio Tail Lights
Changing the 2003 KIA RIO tail lights is not as bad as it looks....
Pry off the two plastic push fasteners holding the stiff carpet covering on the
inside of the trunk over the light.
Pry it away from the light fixture - it will probably scratch the back of your hand leaving small cuts !
The Stiff Carpet Covering is almost ALL of the problem changing the bulbs.
Remove the three yellow nuts protruding from the frame holding the Tail Light Fixture to
the body.
DO NOT MESS WITH THE WIRE CABLE - IT IS NOT A CONNECTOR !
Now - push out on the white button on the side toward the center of the trunk
and pull on the tail light fixture at the same time pushing everything toward the center
of the trunk.
The whole thing is angled toward the center of the trunk lid.
The Fixture will come out in its entirety with a long wire cable inside.
Change the bulbs by unscrewing the bulb holders.
When inserting the Fixture back on, be sure the wire cable is out of the way of
the bulb holder back ends and push the whole thing on angled toward the outside of the
trunk.
Make sure the white plastic peg and the three bolts are going back in the proper places.
Screw the nuts back on tight - pliers?.
DO NOT DROP THE NUTS - or they will fall down inside the carpet covering and be Hell to retrieve!
I had five cuts on the back of my right hand doing the Left Brake Light change...
DoctorBill
Old 12-23-2010, 08:59 PM
badpoor badpoor is offline
Re: Changing '03 Rio Tail Lights
It is a pain like you said even for 2001 Rio read lamps. philips screw driver and a 10mm wrench. best thing to do would be to have a long screwdriver handle like magnetic LED light in case you drop anything down into that hole below the back of the lamp.
Old 07-12-2011, 04:41 AM
leonbentz's Avatar
leonbentz leonbentz is offline
Send a message via Yahoo to leonbentz
I have a 2008 Kia Rio and it's even easier than that. Just remove two phillips screws that are in the rear doorway and the tail light assemblies come right out.
