Go Back   Automotive Forums Car Chat > Audi > A6 | S6 | RS6 | Allroad | A7 > '96 - '04
Old 04-30-2009, 06:51 AM
hobbsta hobbsta is offline
Unhappy A6 Quattro Tire/Transfer Case Issue
I just bought a 2001 A6 Quattro and hit a pothole that ruined the two tires on the right side of the car. I had them replaced with new tires, but the tire shop is telling me I have to replace all 4 tires due to the tread levels being uneven between the new tires and the existing tires. They said it will cause big problems with my transfer case, eventually ruining it unless I repalce all 4 tires at the same time. It would be good to know if this is nonsense or the truth. If anyone can shed some light on this, it would be greatly appreciated. Thanks!
- Tim
Old 11-27-2009, 01:49 AM
Ecmbuster Ecmbuster is offline
Re: A6 Quattro Tire/Transfer Case Issue
This is an old thread but there is limited truth. The circumference of the tire has to be great to damage the "transfer case". That is why both front and rear axles have a "differential". Part of the design is to "accept" wheel speed changes on turns. Total circumference must not be greater than 7mm between each tire or expect the ABS to see the wheel speed difference and set an ABS fault.
Preferred, replace all 4 tires.
Old 11-27-2009, 06:17 PM
99onI95's Avatar
99onI95 99onI95 is offline
Unless his wheels are staggered he should be able to rotate the wheels with new tread on the front and place the wheels with old tread on the back and things should be cherry.
As long as the axels have the same tread depth on both ends there should be no problems.
2010 ALCAN 5000 driver
I own or have owned:
98 Ram Air firebird-WS6 hood and rear decklid, WS6/C5 vette rims, etc.
03 SRT 4-3'' exhaust, short throw, injectors, matte black
E36 convertible BMW-05 17'' BMW wheels
02 Volvo S60 AWD turbo-Stock
00 Audi A6 4.2L V8 Quattro-Potenzas, straight pipes
03 C240 Benz 4matic-stock
04 2.5rs Impreza
05 Chrysler 300C HEMI
04 GSXR-Power commander, K&N, gears, crash cage, suspension, LED tail
