Old 04-29-2009, 09:33 PM
goser goser is offline
Air Conditioning Compressor Clutch
Looks like my air conditioning compressor clutch isn't kicking in. Fuses are okay. Where do I go from here?
'01 Chevy Blazer ZR2 4x4 VIN=W
'80 Yamaha XJ650 Maxim
'08 Jeep Patriot 2.4L
Old 04-29-2009, 10:40 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Air Conditioning Compressor Clutch
Your probably low on refrigerant.
Old 04-30-2009, 03:59 AM
blazee's Avatar
blazee blazee is offline
Problem?
Start the engine,
turn the a/c on high,
pull the wiring connector off the dryer:
Use a paper clip to jump the wires.
If the compressor kicks in:
Disconnect the jumper (do not run the system with the jumper in place)
Check your refrigerant, or have it checked.
Fill if low.
If refrigerant is full,
Replace low pressure switch.
Old 05-03-2009, 12:05 PM
Thanks Blazee, great instructions.
